11.29.2005, 05:12 PM
Yeah, it can't really weight 20 lbs, my aluminum savage weights less, with 18 cells. (and a savage is heavier build than an emaxx) and i used pretty heavy stuff, and this e-maxx is not using 1/8th diffs. (not that i am proud of her weight....) weight sucks.. :p
Do as Country discribed, with the bathroom scale.
The setup i would use on a truck, is a 7-8XL with a 9920, you can use it with 12-18 cells and it will be plenty fast. (and if you just want more torque than your current setup, the 7XL on 12 cells would out perform this hvmaxx.
And you really need other wheels with a strong BL setup, it will shred the hex pretty quick too.. (cant really tell, those rimms look like the orion freshkicks.. the spinners are kind of in the way.. :) )
