01.28.2009, 05:41 PM
Just couple D8 tips - watch your front droop as if you have too much CVDs will be too short. Rear droop is ok.
Screws (with lock nut) that hold turnbuckles to the ackerman can get stuck under the front plastic brace after harder hit. I ended up using socket head screw put in the other way around with lock nut under the ball end. no problems since then.
couple is 2 so thats it :)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
