11.29.2005, 08:45 PM
I bought this loader it can do boht:Graupner Ultra Duo Plus 30
Charges up to 30 Nicads (at rates up to 7 Ah), UP TO 30 NiMH!! batteries, UP TO 10 Lithium!!!! Cells, up to 24V Lead Acid!
The ultimate field charger. 6 x 5-3/8 x 1-5/8", 26 oz. Recharges, conditions, balances, measures capacity of Nicads. Recharges, discharges to measure capacity of NiMH batteries. Charges, discharges to determine capacity of Lithium cells and Lead Acid batteries. Clear instructions, relatively easy to set. Can be adjusted to accept low car (input) battery voltage. For knowledgeable users this charger allows changing of Delta V for automatic cutoff, trickle current. Has adjustable safety timer, click sound when buttons are successfully pressed, buzzer sound for errors and completions. Allows separate charging of receiver or transmitter batteries.
GR6416 Graupner Ultra Duo
Plus 30 Automatic Peak
Charger ..... $ 199.90
IN STOCK
