Thread: BL Tc3
MetalMan
MetalMan's Avatar
11.30.2005, 12:22 AM
If you base anything off of the number of amps a Lipo can handle, look at the continuous. For a 380C 13t (on 4s Lipo?) something with 35amps continuous capability is enough, and won't get very warm. I run a Rustler with a Feigao 540 12s, which is basically the bigger brother to the 380C 13t (for kv), and I run a 3s 3300mah (33amps continuous) Lipo geared rather high. The motor takes the high gearing, and the highest temp the battery has gotten to is about 115 degrees, well within the limit.
