Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
01.30.2009, 08:26 PM
It has that "I just hit a deer on the highway" look.....
That's exactly it! That made me chuckle
Florianz, I can see where you're coming from, but there's no provision for putting a slipepr on the Havoc unfortunately; just wasn't designed with it in mind. It shouldn't be a problem though. The spur is Mod 1 glass-fibre reinforced composite, so should stand up fairly well. And if it does strip, it's easy to replace.
SuperBasher, that shouldn't be a problem. The lexan case isn't airtight by any means anyway, but the pack shouldn't get anything above a little warm, being rated for 175A constant. I'll keep a close eye on it in the first couple of runs, but should be alright.
Thanks again for the compliments guys, really appreciate it! I just got the MMM all soldered up with its motor plugs and deans, as well as the battery. Plugged 'em both in, and all's good so far. It's one of the few V1s still hanging around, but it has the new case and firmware...so I'm *hoping* it'll last well. Should do.
Next and final stop is the motor...
