George16
Supermaxx
George16's Avatar
01.31.2009, 09:02 AM
1. I'm using 4 racerx shocks, 50wt oil all around, blue springs front and black springs rear.
2. I sued to run my gmaxx with 6mm UE cvds. The only reason I'm using the 8mm UE cvds now is because I have it and don't want it sitting in my parts bin.
3. The CoG is so low on the gmaxx that a sway bar is unnecessary in my opinion. The front shocks are mounted on number 7 on the shock tower and outermost hole on the lower arm. The rear shocks are mounted on #7 on the shock tower and 2nd hole from the outboard on the setbacks. I still have to have a rollover.
4. Tires/wheels depends on what you intend to be doing and running at majority of the time. I personally like the badlands mt tires with proline dish wheels. I'm using them with Dace's 23mm adapter. If you already have the monster pirate tires and biohazards, I'd say use them.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
