TDC57
TDC57's Avatar
02.01.2009, 01:02 AM
Protein is the building block to muscle development.
The best method of calculating just how much protein is enough for a ‘high protein diet‘ is with the following formula.
Lean Mass Weight (Kg) x 2.75 = Daily Protein Requirement
(By the way you simply divide pounds by 2.2 to get the equivalent in Kilograms. So 150 pounds is 68.18 Kg)
OK, you first need to know your total body weight and your body fat percentage. If you don’t know your body fat percentage I’ve included calculator in the sidebar to help you. Take a few measurements quickly and stick them into the boxes and hit ‘calculate.’
So now you know your body fat percentage. Multiply this percentage by your total body weight to determine the amount of fat you are carrying. Now simply subtract this from your total body weight to ascertain your lean mass weight.
Take this figure and multiply it 2.75 to give you your ideal protein intake per day in grams.
Example
A man weighs 150 pounds with 15% body fat.
• 150 / 2.2 = 68.18 Kg
• 15% x 68.18 = 10.23 Kg
• 68.18 - 10.23 = 57.95 Kg - Lean body mass in Kg
• 57.95 x 2.75 = 159.36
So, therefore our 150 lb, 15% body fat man should be shooting for 159 grams of protein in his daily diet.
P.S.
One book I’ve been thinking about getting is this one (??) http://www.bottomlinesecrets.com/sto...sid=Y101308A2D
The world’s greatest treasury of Health secrets..
Has anyone read this one book?
Nothing!.. Hahahahaaa..
