02.01.2009, 08:21 PM
Originally Posted by alangsam View Post
i find that if i dont keep my slipper screw as tight as possible the slipping causes a tremendous amount of heat to the point where the clutch smokes!
i like the idea of a slipper to cushion the drivetrain. what else have you guys done?
i am running 8xl's +MMM + 6S in my erevo and 4S in my emaxx and similar behavior.
Actually i was running 2 8XL's but smoked one running 6S as i was warned on this forum and have my 2200 castle on order.
Well, you may need to rebuild the slipper since you smoked it. Best method is to set the slipper tight, and then back it off incrementally until it slips too much. Then tighten it a bit and you re good to go. 8xl on 6s must be a beast...
