Originally Posted by lincpimp
Well, you may need to rebuild the slipper since you smoked it. Best method is to set the slipper tight, and then back it off incrementally until it slips too much. Then tighten it a bit and you re good to go. 8xl on 6s must be a beast...
I put a complete new slipper in and same issues need to keep it real tight otherwise the motor overpowers and it slips too much. i am sure if i did in tiny increments i could find the spot. would be nice if there was something a little beefier.
