Also
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Also - 02.02.2009, 10:16 AM
Oh yea and I forgot that I am doing the Mod suggested by Lito. I purchased some (12 = 18") 1/8" hardened steel push pins from Plastixx to make up custom hinge pins. The front set are already done and installed. I drilled & tapped out the 3mm setscrew holes on the RCM hybrid dulks to 4mm. The pewny 3mm setscrews stripp out too easily. Anyway I cut each hinge pin to a custom length, and placed a precise capture groove where the setscrew hits the pin, and that keeps them from comming out. No E or C clips here, and no worries that anything will come apart duing opperation either. It is my hope that this Mod will help prevent bent hinge pins, and having to fight to remove them. We shall see.
SUPERMAXX YOUR LIFE.
