02.04.2009, 08:42 PM
Neither should twist in that application. I would stick with the 1/8 shaft, unless you plan to make your rusty very heavy with al crap. Sticking with the 1/8 shaft will allow you to continue using the 48p pinions and spurs... 10th scale is fine with 1/8 shafts...
