marzac2
marzac2's Avatar
02.05.2009, 03:21 PM
Teknorc: I was curious what effect, if any, that the long shank pinions have on motor bearings? During operation, doesn't the flexing/twisting of the chassis put stress on the motor bearings (front especially) from the spur/pinion pressing together?
BTW: I'm not trying to slam the product, just was curious about your thoughts on this...
Brian, thanks for your questions. No negative effects have been seen at all. This is due to the bracing around the gear mesh area thats included in the Tekno kits. This keeps the twisting/flexing confined to only specific areas of the chassis (kinda like a tuned flex Losi chassis).
Originally Posted by js058515 View Post
I figured you had that base covered......and I have been holding off on more motor purchases because I was hoping for square can versions of the 1512 and 1509. Which and when are they going to be available? The square 1515 in my 8t has been awesome. It's been worth the price.
No official plans as of yet. But be on the look out, I spy something new on the horizon...
Originally Posted by cwallis View Post
Are there any plans of making blue spacers and longer screws for the revo motor mount? This is something I have seen other member do, to allow them to get away from the long shank pinions. It would be nice to have parts that were colored the same as the mount, it would be something I would be interested in. This would allow me to use the same pinions that I use for my erevo. If not, I will send in for the new three clutch system with thinner spring.
Sorry, but the long shank pinion are the only option for direct drive. Reason is because of offering the clutch option and this requires more room. I encourage you to try the new clutch. We have been getting very good results.
Originally Posted by himalaya View Post
Good point. I've suggested Tekno in another thread to have Clutch-Free version of theire conversions, using standard mod 1 pinion instead of long shank for customers to choose from, but not very likely to be accepted.
So far Tekno is the only one insists using of a clutch among all those available 1/8 conversion kits, RCM, Novak, CC, RCdesign produts, Losi, AE, and new Hongnor.
Thanks for your support!
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
