Originally Posted by Semi Pro
its in my sig lol but here goes
revo platinum with 120k center diff
tekno Nue 1515 2.5D F
5 cell lipo
castle creations HV110 esc with CC BEC
revo responce tires
geared 16/36 33mph
my slipper is set fairly lose (the truck will not lift at all) the drive train is silky smooth, nothing binding or catching with cermaic bearing
after 5min my clutch is +325 degrees
i have tried alot of things includeing diffrent shoes,springs as well as 3 and 4 shoe clutches and vented clutch bells
i am haveing to change clutch shoes every race (traxxas stock revo)they are often deformed around the pin, blue in color and melted
i have tried sanding the clutch bells,and even running without clutch springs
i need a real fix for this before this season starts, i exchanged emails with tekno last year about this with no results
All sounds normal (setup that is). Let's try again. A couple questions.
How hot is your slipper getting?
Can you hear the tranny shifting?
Are the shoes totally covered by the bell or is there some exposed?
Any pics of the Elektri-Clutch installed on the vehicle?
What's your top speed like? Do you feel you're calculated setup meets your actual?
Are you going to send in your old Elektri-Clutch for the new one? If so, include some of your worn shoes so we can take a look at them?
I guess that was a few questions. Hopefully we can fix this up for you. Thanks.
