Semi Pro
Semi Pro's Avatar
02.06.2009, 02:26 PM
for tekno Rc
-How hot is your slipper getting?
i have seen temps varying from +200 degrees all the way up to 325 degrees on high bite tracks
-Can you hear the tranny shifting?
yes and if it didnt you could easly tell by how slow the truck would be going if it didnt shift
-Are the shoes totally covered by the bell or is there some exposed?
they are covered and the bell is properly shimmed, the shoes have 1 .001 shim behind them so they dont rub the flywheel
-Any pics of the Elektri-Clutch installed on the vehicle?
i can take some when i get home tonite, what exactly do you need to see?
-What's your top speed like? Do you feel you're calculated setup meets your actual?
top speed is 33mph calculated and radar varified (most of the tracks are tight and lose in my area so i dont need alot of speed)
-Are you going to send in your old Elektri-Clutch for the new one? If so, include some of your worn shoes so we can take a look at them?
im only going to send it in if we can fix the problem, other wise im not sure what i will do since im not happy with the long shank pinions. i dont have any ruined shoes at the moment but it wont take me long to ruin afew to send in with it.
