Originally posted by HotnCold
I would run the 9L - The can on the 9L is much smaller than the can on the C50. You have a lot more tuning options with the 9L than the C50 IMO. Also i would guess that running a 51 tooth you would probably run a 18 or 19 in first gear - should get ya to around 28-29 mph in first low 40's in second but motor and controller temps will rise fast in second... If my calcs are correct - Mike?
C50 is rated for a higher heat dissapation, higher RPMs, and same torque. The only fallbacks are price and size.
I don't really understand what your saying, a 9L made by feigao? B50? C50? They all make a 9L, though most people only know of the C50 maxx, which is a 12s.
