Originally Posted by teknorc
One more question, how are the shoes installed?
If the two pins are 3 and 9 o'clock for example, is the 3 o'clock shoe on top or on bottom?
Your slipper seems like it's a little loose, although that shouldn't affect the clutch temp.
i have used them both leading and trailing with no affect on heat, right now my clutch is slipping alot more than the slipper, im only replaceing slipper pads and plates every 12-15 races.
i normaly have them installed leading as per tekno's instructions
the slipper is set to save the diffs and keep the wheels down when going to wot comeing out of a corner.
