SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.06.2009, 08:50 PM
Finally a 1/8 buggy that is designed for electric from the ground up. The diff in the rear really opens up space in the chassis and allows the battery to sit right next to the center drive shaft. Also the straight drive shaft will almost eliminate wear on the drive pins as they do not slide back and forth in out drives.
Area 52 Ranch Raceway
T.R.C.R.
