George16
Supermaxx
George16's Avatar
02.09.2009, 06:10 AM
I'm running 50/15 and my temps are the following:
ST-RR
50/15, 5S
ESC – 104
Motor – 131
Batteries – 100
However, give it a try first and see what the temps are then just use the guideline below.
I got this from one of the posts here in RCM:
Although not always true, a rule of thumb is:
Hot motor, cool controller, cool batteries = undergeared
Cool motor, hot controller, hot batteries = overgeared
Warm motor, warm controller, warm batteries = happy components
hot motor, hot ESC, and hot batteries = overgeared
Hot, warm, and cool vary as well, so here's another general rule:
Hot for a motor = generally over 160F (71C)
Hot for a controller = generally over 150F (66C)(or "thermal" range for the controller)
Hot for batteries = generally over 150F (66C) for nimh, 130F (54C) for lipo
Warm for a motor = generally 100F (38C) through 150F (66C)
Warm for a controller = generally 100F (38C) through 130F (54C)
Warm for batteries = generally 100F (38C) through 130F (54C) for nimh, ambient temp through 120F (49C) for lipo
Cool for all components = generally ambient temp and up to 10 degrees F (5.6C) more
The reasons the above are not always true are numerous, but may include:
Sticky drivetrain - will put un-necessary strain on electronics whether geared correctly or not.
Poor quality batteries - batteries will heat up regardless of gearing.
Wrong motor for the application - will put un-necessary strain on electronics whether geared correctly or not.
Wrong controller for the application - will put un-necessary strain on electronics whether geared correctly or not.
The list goes on, but this can give you an idea of things to watch for.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
