what wheels work with the super bolt on tires?
alangsam
what wheels work with the super bolt on tires? - 02.09.2009, 04:52 PM
Originally Posted by E-fanatic View Post
Well the losi's offer better overall grip and are ribbed inside so they don't balloon up at high speed very much. That was there down side b/c even with the slipper set so loose that the truck wouldnt wheely it would still eat a shimmed diff. The badland are more sensitive to steering inputs and offer less grip (so it will help the diffs last longer). They also need to be taped (I used gorilla duck tape ) so the tires wouldnt balloon at higher speed(they are not ribbed inside to prevent it) . Both tires handle completely different! I do like the badlands and would recommend them(the only downside to big lugs on a tire is lak of grip on hard packed surfaces)
Since you have the e-revo I would say go with the badlands b/c the e-revo's diffs cant handle the extream grip and weight of the losi's tires.
I ordered the maximizer badlands combo. I also want to know what wheels do the lost super bolts ons fit? will they fit on the 17mm maximizer or do i need a 40 series rim? if so does anyone make a beadlock in a 40 size?
