Hardstyle
Hardstyle's Avatar
02.15.2009, 09:45 AM
Originally Posted by spiftacu1ar View Post
Ok, so I finally finished building my truck, I plugged in my lipos (not fully charged, the cells are at 3.7v each, so at storage charge, not dead either) The first thing I noticed was a large spark as I plugged in the batts. The car still ran, but I am not sure that it is normal. I am using deans ultra connectors, and have the batteries wired in series via a "Y" shaped adaptor I made using 3 deans and 3 wires. (mamba + to battery 1 +, batt 1 - to batt 2 +, batt 2 - to mamba -) All works well when plugged in, as I can drive the car (only went in a small circle in my room to make sure everything works). THe spark was pretty big though, and it kinda scared me, so I wanted to make sure that the spark is normal. Is there something I can do to prevent it?
The spark is completely normal when connecting the plugs, it's something to do with the plugs charging up. The bigger the batterys the bigger the spark. It's nothing to worry about, it does wear the plugs a bit but thats all. There is a way to prevent the spark, but it is forbidden to mm/mmm controllers.
Also, i noticed that running the vehicle produced a very high pitched noise under acceleration. Also wanted to verify that this is normal.
This might be the slipper. You should look that the slipper is tight enough, that it won't slip too much under the acceleration. Not too tight either, so your drivetrain will last longer
