A little progress . . .
dangerwr
A little progress . . . - 02.15.2009, 08:48 PM
Ok. I have been really busy with work and grad school so I have not been working too much on the conversion. I received the steering servo yesterday and found a good deal on a Futaba R603FF 2.4GHz FASST Rx--gotta love the digital stuff.
Anyway, I have raised the motor top plate as recommended by SSSP and bolted up the 51T spur. I still have to take some time in our model shop to cut the SST tubing to prevent solid spool from shifting. Looks like I will extend the grub notch on the shaft the Neu if I stick with the Novak pinions. Also, I need to find some of that 10AWG wire that CC uses on the MMM. Check it out . . .
