sikeston34m
sikeston34m's Avatar
02.15.2009, 10:22 PM
My main question is can I rewire a neu 2y to a neu 2d...
This 12 tooth field isn't a 2Y winding. It's wave wound.
Do you have an example of a Neu 2y handy?
Sorry for being so difficult, but I believe the 2y will be a different configuration altogether.
To answer your question, I'm sure it would be hard.
Usually the winding for Delta is continued on both sets out to the main leads. Some manufacturers like Medusa choose the make the leads out of the winding wire itself. (It's why Medusa leads are so stiff)
If you were going to simply change from wye to Delta without rewinding the entire thing, when you separate the wye termination point, the leads will be too short.
It can be changed, but you have to rewind the whole thing.
