dangerwr
02.16.2009, 08:35 PM
Originally Posted by Blunten View Post
The screws that holds the spur will start carving into your motor mount. You just need one bearing on that side and make sure you put the flange side on the spur side that way it wont cause friction onto the center diff bearing.
The photo does depict a single flanged bearing on the left side of the spur--I need to flip the flange to the side of the spur. My RCPD motor mount must have the main bearing more recessed than the one you are using and is why it can not be seen in the photo.
I went back and placed both bearings on the left side and everything fits well. I will need to extend the notch on the drive shaft for the set screw on the spur hub.
