sikeston34m
sikeston34m's Avatar
02.16.2009, 11:43 PM
Originally Posted by SpEEdyBL View Post
Not entirely true. Lower kv motors make more torque per amp than high kv motors, but high kv motors will draw way more amps. Also, when you use a smaller pinion gear, you also increase torque at the wheels.
Let me explain this another way.
A high kv motor compensates for it's lesser torque with lower gearing. Lower gearing multiplies Torque, does it not?
A high kv motor does draw more amps than a low kv motor under NO load.
How many amps a motor pulls depends on how loaded it is. This applies for ANY motor with ANY kv. The higher the gearing, the higher the load is for the motor.
A lower kv motor has MORE torque. Torque is it's ability to overcome resistence. There is a way to measure it. This statement is true.
The lower kv motor is geared higher because it doesn't need such a low ratio to multiply torque.
Now back to the original purpose of this thread.
High kv low gearing VS Low kv high gearing.
Total Watts of power delivered is what needs to be considered.
A Lower Kv motor geared higher will pull more amps. If it were possible to match two setups, one high kv low geared, and one lower kv high geared where they drew exactly the same amount of amps on the same voltage.
They would deliver the same Total Watts of Power. They would be the same!
Watts = Amps X Volts. Higher voltage setups trade amps for volts in this equation. Wire size is limited in RC. We don't use cables the size of our thumb. The largest wire size most use is 12 Ga. 12 Ga. wire has it's limits. The greater the length of the wire OR the smaller the gauge wire, the greater the resistence AND the greater the voltage drop. This hurts efficiency.
The Total amperage drawn is what creates heat especially in wiring that is being pushed to it's limits. Heat is wasted energy.
The final voltage delivered to a motor, after voltage drop values due to wire size is considered, is enough to affect overall performance.
Any differences in the setups would stem from differences in overall efficiency. Lower kv motors tend to be more efficient because higher voltages are used with them.
Also Lower kv motors are more efficient for 2 reasons:
1. It doesn't have to spin up to such a great rpm.
2. The phase switching on the ESC is less.
