02.17.2009, 12:21 PM
Yeah, def get a vid.
On the slipper, I found using a temp gauge works pretty well to figure out if its slipping or not. If its warm/hot, you know you got an issue. This applies to a lot of things one the car. Once I found a cvd that was 170F! Little binding in the cup was causing excessive wear, but not something you would necc check for.
