SunnyHouTX
SunnyHouTX's Avatar
02.17.2009, 02:35 PM
BTW, for the way the rear end is set up, I'd recommend a direct drive system which is very easy and cheap to do. You don't need any more than 3S to get a very quick dragster. With a motor of around 4000kV, and a 3S lipo around 2000mAH, you will get in the 1.7sec ET range around 65 - 70 mph in the alotted 132ft. You will only have to play with tire diameter to go faster.
