Thread: Got an Emaxx
brushlessboy16
brushlessboy16's Avatar
02.18.2009, 06:23 PM
Originally Posted by mkrusedc View Post
The cup is plastic as is the case. This allows for flex and then the gears strip. The ring gear screws are too small. At a minimum get an aluminum diff cup, the modified ring gear with 3 mm screws and an aluminum diff case. This at least theorecticly corrects the flaws of the 3906 diff.
...or you could spool it.
ohh, thinking a diff for the front and rear spool.
