dmeylman
02.19.2009, 01:01 AM
Yes, you need more juice - that set up should be run on 4S. Is there a reason you tried it with just one battery? Also, why did you order two 15T pinions? Also, how did you mount the motor, seeing that you have a motor mount on order?
actually, i just use that battery to test it...(that's my b44's). i ordered 2 pinions, just in case one did not work...also the motor mount for the same reason...anyway, i am buying a 3s, you think it's good enough??? here's some pics...
