Thanks.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Thanks. - 02.19.2009, 03:51 AM
Originally Posted by satan'struck View Post
Just take alook at this web site http://www.speedpassion.net/ GO UNDER PRODUCTS, THEN 1/8 COMBO SET, the ESC is Silverarrow, and the Motor is Silverarrow 6.5R V10! Both are for 1/8 Scale...Price is about HK$2,000.00, so is about US$260.00 a set. Should be a pretty good for you guys!!! BTW, since I ordered all these stuffs...
Robinson Racing Hardened Steel Spur Gear 68T New E-Maxx 1 $27.99
Robinson Racing Dbl Disc Slipper Kit Steel 72T Traxxas 1 $36.99
Robinson Racing Xtra Hard 5mm 8 Mod Pinion 22T 1 $11.59
I think those stuffs that I ordered from RR shoul work ONE WAY OR THE OTHER!!! If not, then that's just SIMPLE(I ORDERED THE WRONG STUFFS)
Thanks for the info on the Silverarrow ESC/motor combo. Once you post up your test results I may have to try one in one of y Maxx project trucks. I do like the way it looks.
As for the RR DD slipper stuff I havedone the same thing on other purchases that I have made. That is why I have lots of spares for my trucks now. Such is life.
SUPERMAXX YOUR LIFE.
