JeffEmbracedDC
JeffEmbracedDC's Avatar
02.20.2009, 04:13 PM
Yeah - that motor is going to run hot. There's pretty much nothing you can do about it. I mean - you can drop the timing down on the mamba max, gear down a little (but it seems low enough as it is), turn on some punch control.. but other than that - it's just gonna be a hot motor.
You should simply upgrade to the mamba monster 2650kv combo. That would be the way to go for 4s. If you end up going 5 or 6s you have other motor options that are either more expensive (neu, plett, etc) or less expensive and not as effecient (feigao, medusa, etc). Personally I would stick with 4S and run the 2650kv with the mamba monster.
Yes - the steel spur is crazy loud. The plastic one is a LOT quieter but still makes a racket. I like running plastic personally. Never had problems with them and they're MUCH quieter.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
