Hardstyle
Hardstyle's Avatar
02.25.2009, 07:02 PM
Originally Posted by jzemaxx View Post
If you figure out how to do the emaxx transmission, lets talk. I need some more speed and this trans is maxxed out on gearing.
Sure do. This is all in theoretical level still. Have to think other options too..
I'd do something different!
I'm thinking an RCM centre diff mount or two of your choice mounted between the TVP's with a buggy diff... Should be easy enough to create plates to hold the diff mount...
That gets rid of the brake setup - the two speed and the ugly motor mount.
It should also give you plenty of room to move the battery inside the TVP...
Not sure if I understood correctly. You mean two of these rcm motor/diff mount thingies and centre diff between them? Does it work?
Thats funny cause I have thought the same thing. But wasn't really sure about it.. Practically this? http://www.rc-monster.com/proddetail...d=RCMLosiMount
