02.26.2009, 02:06 AM
Originally Posted by pasan View Post
I think the Blinky somehow can't quite bring the rest of the cells down to that voltage and keep them there. I usually charge while balancing. I too think a balance charger is best but I'd like a charger which actually does something more than a balance, i.e. by pushing extra juice to a weak cell to bring it up to par rather than bringing the others to voltage of the weakest cell, which IMO is very inefficient.
Only way to get what you ask is to use a seperate charger for each cell. Any charger on the market charges the entire pack of cells in series. Only way to equalize them is to put a load on the higher cells and bleed off some juice. If you had a seperate charge curcuit for each cell the balancer would not be needed, as each cell would go thru the cc/cv cycle on its own terms, so to speak.
