smaller pinion for more voltage
alangsam
smaller pinion for more voltage - 02.26.2009, 08:58 PM
Originally Posted by fastbaja5b View Post
So based on what is being said here, one should be fine to run it on 6s with the 20t pinion and if anything it should be easier on the system than running on the 25t pinion
so why are we being told that to run on 6s we must run the 25t pinion as is the feedback here:
http://www.ausrc.com/forum/showthread.php?t=15868
Where the blame has clearly been laid on the user running the 20t pinion and not the 25
If anything, if you're going to change gearing shouldn't it be down to like a 15/16t pinion?
And I still haven't had a reply from castle support, been what, 3-4 days now? :( not cool!
guys this is math higher voltage needs smaller pinion larger spur = less current = cooler esc. start with a smaller pinion like 18t and see what the temps are like then go up and see where things are. if you want to go 60 things are going to break. better to gear for 40's and things will last and you can focus on driving vs repairing
