Pdelcast
Pdelcast's Avatar
02.28.2009, 01:50 AM
Originally Posted by SpEEdyBL View Post
The main reason people don't use it is because the cutoff is two low. CASTLE, MAKE IT 3.2 VOLTS INSTEAD OF 3.0 IN THE NEXT VERSION OF CASTLE LINK! Or adjustable by the user.
Well, we will be adding an adjust to a future version of the software, so that the cutoff threshold can be changed.
As it is, the cutoff is closer to 3.1V than 3.0V right now, and Lipo chemistry doesn't actually start any damage until a cell hits about 2.4V -- so there isn't any problem with using 3.0V as a cutoff.
And yes, the auto-lipo mode assumes that the batteries are at full charge. HOWEVER, the Monster controller ALSO beeps back the number of cells to the user -- so the user can verify that the number of detected cells is correct. (you will hear the normal power-up beep, followed by beeps for the number of detected cells, and then followed by the arming tones.)
Patrick del Castillo
President, Principle Engineer
