03.04.2009, 02:10 PM
Originally Posted by mriccucci View Post
This one is SWEET
http://www.newegg.com/Product/Produc...82E16817153070
I used an earlier revision of this unit to build a supply a while ago. Preformed well. steady 12v due to the usage for the higher end video cards. This ones a little much but its like a 60a total output on this power supply.
That one has two 12v rails, so each one probably has around half the total. I kinda like the 52A model posted above by magman (http://www.newegg.com/Product/Produc...82E16817139005) because it is a single rail supply. In either case, I would definitely open it up and replace the small wire bundles with 12GA or 10GA wire soldered directly to the PCB. I wonder what kind of tricks can be done to these to boost the 12v to something closer to 14v?
