Gustav
Gustav's Avatar
12.07.2005, 08:44 PM
They should do i think when all 4 wheels are on the ground because they only have half a truck to shift.Only problem is when the front wheels are up the rear motor will be well loaded.That's why i was thinking to suggest to dagger thrasher to use a 9920 in the rear and 7020 up front.Although as you have proven the 70 amp warrior is rather robust and since the 4200 doesn't pull so many amps anyway.
