03.05.2009, 11:06 AM
Specs look ok, if a bit low. If specs aren't inflated, it might be ok running 4s on a low kv motor in a light 2WD 1/10 scale (max) vehicle; anything larger, or lower voltage, will probably exceed the low 40A spec. And it looks like it doesn't have a switching BEC, so if running anything over 2s, you'll need an external one or a receiver pack.
It's really hard to say though. There is more to an ESC other than specs: customer service/warrant, upgradability, smoothness, etc
