mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
03.05.2009, 07:40 PM
Originally Posted by squeeforever View Post
My bad. I could have sworn I saw the nitro ones start to use them as well. Still, the E-Revo and Revo diffs are different. That was the original debate anyway.
It gets confusing because when the original 2.5 Revo was released, and the 2.5r and the 3.3, they all used the same diffs. The new Revo 5308, 5309 and Platinum edition also use those same diffs. The diff carrier for the nitro Revos, the Slayer and the 3.3 TMaxx is TRA5381. The electric version of the diff carrier used in the ERevo, EMaxx is TRA3978 and it comes with the metal spider gear braces. These braces will not fit in the TRA5381 diff carrier of the nitro vehicles. Here is a pic of the nitro diff carrier on the left and the ERevo diff carrier on the right. You can see the recesses in the ERevo diff carrier for the spider gear braces. Surprisingly, if you need to get the output gears TRA5382X, they are the same for both the nitro and the electric. It is basically the output gears used in the EMaxx and come with the center metal ''I bar''. Originally, the output gears part # was TRA5382. Apparently, this has been discontinued and replaced with the EMaxx TRA5382X that includes the I bar and can be used in both nitro and electric diff carriers.
Also when you look at the exploded view of an ERevo diff, it shows a drawing of the nitro Revo diff carrier even if it cannot be used with the ERevo's spider gear braces, that were originally released in the EMaxx
I'm stopping 'cause I'm starting to confuse myself.
No brain, no headaches.
