Hardstyle
Hardstyle's Avatar
03.10.2009, 11:41 AM
Center diff and housings arrived today. And with my luck the housings seems to be wrong ones It's very minor problem. Housing is 15mm and bearings are 16mm. So I think I could work that housing a little bit. Maybe drill the hole little bit bigger.
Good news is that the cen dogbone fits there perfectly.
Arct1k, is that center diff one you recommended? Might those phillips screws be a problem with Mike's mount?
