tkhoo
03.11.2009, 02:13 AM
I would be careful about using such a physically large ESC as it will sit rather high which is a potential danger zone should you land square on the lid. A MM with a UBEC if running over 2s would be ideal size-wise.
And I know you said you can't afford a Medusa, but honestly, they are about as good as you're gonna get for the price. Save up a couple/few weeks, you won't be disappointed. The cheap motors (Feigao and similar) are less efficient and you can really tell by the heat they produce.
Ideally, a MM with a Medusa 36-50-3300 running on 3s lipo with a UBEC would be the best bet IMO.
Hi, if I using 60A HW esc can this medusa will nicely pair up together with 3S? Medusa is 3 or 5mm shaft? Do you ship to Malaysia?
