nl12
nl12's Avatar
12.09.2005, 10:23 AM
I have multiple times, the only thing i can think of is that removing the jumper with the batts unplugged doesnt disable the bec and with the ubec it messes up the recever. I will try to reprogram it when i get home from work though, the thing is I could not get it to program with the ubec pluged in, only in bec mode, ubec mode steering would work fine untill i plugged the controler into the recever, then it went screwy (this is with the black jumper removed btw)
