Thread: Lipo repair
03.13.2009, 11:29 AM
Another little bit of info. Note that I have a small ziptie on the balancer wires. I do this to keep them together and provide a bit more strength. On the enerland cells that have tabs on each end some of the tap wires run along the side of the pack. I tape them down to keep them in place. The tap wires that attach on the top of the pack are looped under the tap to give them some strain relief. Some people are a bit rough with balance taps and this helps the wires survive and not tear off where they are soldered. Seems like zippy and venom packs are bad about this, as the align style taps usually have the thinnest wires in the balance harness.
Just a little info I though I would share.
And these packs make an even 200 enerland based cells that I have worked with in the last 2 months! I am sick of soldering, my big gun style iron that I use for the large wires is about worn out! God only knows how many packs I have fixed/altered by now. Must be at least 250 packs. Seems like all I do is solder on lipos!!!
