Jeremy1976
03.16.2009, 09:02 PM
The answer is to not expect the performance of a higher end pack out of the low priced pack you can afford. If you can't afford the "Ferrari" then you can't afford it, but you can't buy a "Chevy" and complain that it isn't a "Ferrari", either.
It isn't the low end packs in and of themselves - it is the low end packs being used like high end packs that are the issue. If you want to see the 60mph speed on the box of the ERevo, you need to have Ferrari packs to do it reliably. If you have the Chevy packs, then don't try to reach Ferrari speeds and you should be fine.
Great metaphor!
