93firebird
03.16.2009, 09:40 PM
Holy crap a 66t mod1 spur? That's HUGE!!
I'm pretty sure the genesis center diff uses a 44 tooth spur gear, which should swap with the matrix spur gear with no problems. I checked on cens web site and found that they both use the same plate on the opposite end of the diff housing. Now the genesis only uses it on the front and rear diff's as the center has another gear on it. But the front and rear diff housings are the same as the center diff housing. The plate I'm talking about is the gs060.
