doo540
03.17.2009, 05:47 PM
just were have you seen brushless 5B's running around? If it was done by Fine Design then yes it was probably not that fast and not that great. Stock 5B's only run around 40mph out of the box, you know brushless will be faster then that top end and take off, no way a gas will hold a candle to brushless. I'm talking neu 2215 on 37 volts, not a 1515 size motor.
lipos 220.00=10s 5000 zippy, I have seen cheap 100.00 esc work on the baja from across the pond. BL is so much cleaner to work on and bring into the house for those really bad repairs.
