03.18.2009, 01:07 AM
Hey WN, did you ever get the Sentilon to startup well? I just went back and read the thread you had. You gearing was steep...
Looking at the baja 5b it has a 17t pinion so the stock motor must do something like 15k rpm max. With the 1521 motors on 10s I am getting 28k rpm, so I think 2 of them with 12t pinion will do the job.
Heres the calc, eyeball it and see if I got it right???
Differential Ratio: 1
Transmission Ratio: 2.4000000000000003
Other Ratio: 1
Spur Tooth Count: 57
Pinion Tooth Count: 12
Total Voltage: 37
Motor KV: 780
Tire Diameter (inches): 6.6875
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.025
Spur/Pinion Ratio: 4.75 : 1
Total Ratio: 11.4 : 1
Tire Circumference (inches): 21.01 inches (533.64 mm)
Total Motor Speed: 28860 RPM
Vehicle Speed: 50.37 mph (80.91 km/h)
Effective KV Value: 780
KT constant: 1.73 oz-in/A
