SpeedAssault
SpeedAssault's Avatar
03.18.2009, 09:41 PM
RC-Monster is the Encyclopedia Brushless- read everything....
Nah, I have a few FAQs and Tutorials in my sig that explain the different types of escs and BL motors, plus the different types of lithium batteries in great detail, but with plain English language and explanations.
There are also a multitude of other FAQs that are stickied in the General and Brushless sections, with even more info and explanations.
As for whats best, it depends much on your personal needs/desires, and budget; looking at similar builds to your own will yield usual info too.
The thread below lists peoples personal setups with various vehicles, with info on gearing and such to make life easier:
http://www.rc-monster.com/forum/showthread.php?t=6423
Given the vast number of options out there, its a bit unrealistic to compile a list of escs, lipos, motors etc etc, but if you look at BrianG's calculator, it lists most of the popular motors that we tend to use.
On the esc front, 99% of whats easily available is 4-6s lipo at most, with only the $$$$ Schulzes and MGMs going higher in voltage; exception is Lutach's LT-10s esc. A 9lb vehicle should do fine on 6s lipo though, even if it is a stretched maxx.
Hey thank u suicid
I'll look at the FAQ stickies
I found this battery but it does not say what # lipo ? ? ? So do I just pay a attention to volts and amps ?
25c/50c 18.5 volt 5000mah Lipoly Battery pack
Made from super powerful 2500mah cells, Factory rated for 25c continuous and 50c burst discharge capability. a whopping 350 amps burst on this pack
Capacity - 5000mah
Voltage 18.5v
Cont. discharge - 25c(125amps)
discharge - 50c(250 amps)
Your sig link "Brushless, lipo & LVC tutorials" No worky
Thank you
I am thinking a MMM but I dont know the importance of sensored ESC's
