Mozzy
Mozzy's Avatar
03.18.2009, 11:44 PM
I did alot of research on the km baja's and their suppose to be every bit as good as the hpi baja 5b rtr version but half as much. Every part is compatible accept the battery box on the km baja is a little different but it can be switched out.
I hate to take you down, but, these knockoffs are exactly that!
The plastics are weaker, clutch & spurs melt, engine is....ok, but, pullstart breaks easily, servo's are crap & literally stop working after a few hours or the spline shears off the steering servo.
Best part is that the alloy bends & bends back without breaking! Good for two bends only.
I've had both an original HPI & these crap things in front of me & driven both. They're not worth it.
You will spend hundreds if not thousands of $$ over a short period to bring it up to HPI standard each time it breaks.
& for the record, HPI plastics are made in the same factory as a few other high end nitro buggy & truggy brands, just can't remember which one's, in Taiwan.
China rips things off because the copyright, patent & legalities that apply in other countries don't apply & can't be enforced in China. Shenzen, China, is the place where most of the knock off crap comes from.
Quite a large can of worms opened here.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
