jsr
03.19.2009, 03:44 PM
Fans are easy. I've replaced so many fans, I've lost count (these are home-made setups where I made brackets attached to the chassis). Regardless, fans are easy to replace.
Just to clarify, the MM has a BEC, but the EZRun has a UBEC (switcher).
Also, while the ginormous size of the EZRun does make placement more difficult, the additional mass (PCB, heatsink area, and contact area to heatsink) for thermal dissipation should help with heat issues.
