03.19.2009, 11:34 PM
Originally Posted by emaxxnitro View Post
i dont think any drive train could take 2 1527's 1 is hard on it.
dual lt- 10s's it would be cool to see
I do have 1 lt 10... I will be retaining the mech brakes on this, and most likely adding front brakes too...
People put the big worked over gas motors in bajas and push some hp thru them. If an emaxx/lst can handle a 1521 a baja that weighs twice as much needs double the power a 1521 can deliver, at least that is my thoughts on the matter. Plus the motors will only be loaded so much, as this is 2wd and has basically 2 40 series tires. And it is going to be geared for 50, so not a huge load there either...
I will give it a try, if it does not work well I can always sell the equipment and mounts that I make and put it back to gas power...
